This is what GlobGnd and GkVFLss described in PVsyst help
GlobGnd Global incident on ground, below the system.
ReflLss Ground reflection loss (albedo)
BkVFLss Loss due to the view Factor for rear side
So I think GlobGnd is source energy for other parameters such as ReflLss and DiffGnd etc. That means value of GlobGnd should be the largest during these parameters.
But I processd some simulation  and looked into details of results. I found that BkVFLss always larger than GlobGnd. Does anyone know why about this?
  GlobGnd DiffGnd ReflLss BkVFLss
  kWh/m² kWh/m² kWh/m² kWh/m²
January 26.1 9.94 13.06 18.8
February 41.5 13.76 20.73 35.4
March 70.9 23.17 35.45 67.1
April 98.7 27.04 49.34 96
May 125 28.2 62.51 121.1
June 124 29.7 62 119
July 122.1 32.43 61.07 117.3
August 103.1 31.35 51.56 99.9
September 75.3 24.16 37.64 72.3
October 52.8 18.7 26.41 47.2
November 30.3 12.88 15.13 23.6
December 20 10.03 10 14.4
Year 889.8 261.35 444.88 832.2
albedo=0.5   GlobGnd=889.8   BkVFLss=832.2
January 26.1 9.94 5.22 30
February 41.5 13.76 8.29 56.7
March 70.9 23.17 14.18 107.4
April 98.7 27.04 19.74 153.6
May 125 28.2 25 193.8
June 124 29.7 24.8 190.4
July 122.1 32.43 24.43 187.7
August 103.1 31.35 20.62 159.9
September 75.3 24.16 15.06 115.7
October 52.8 18.7 10.56 75.5
November 30.3 12.88 6.05 37.7
December 20 10.03 4 23
Year 889.8 261.35 177.95 1331.5
albedo=0.8  BkVFLss=1331.5
Hi,
The reason is that GlobGnd, DiffGnd and ReflLss are variables that refer to the m^2 of ground area.
Whereas, BkVFLss refers to the m^2 of PV modules.
If you were to mutiply by the respective surfaces (ground surface > module surface), the energy hierarchy would make sense.
