Chen Posted January 8 Posted January 8 Dear Prof.André Mermoud: Recently, I have utilized PVsyst 8.0.19 for simulating the IV curves of BC modules under module-level and string-level shading scenarios. Given some inconsistencies identified in the string-level results, I wish to arrange a discussion with you on this matter. I increased the Arev factor of BC module to over 1000, and first simulated cell shading at the module level with 1 cell shaded. The results showed a 35% power reduction. When I used the string simulation tool to replicate the same number of shaded cells—i.e., a string configuration with one module per string and 1 cell shaded—the results displayed a significant discrepancy. Does it a bug? Does the Arev factor of BC modules fail to take effect at the string level? thanks! Best regards!
Luca Antognini Posted January 14 Posted January 14 Dear Jianguo Chen, Thank you for your feedback. I share your understanding : both dialogues, with those parameters, should lead to the same results. For me the correct plot is your top screenshot, from the menu "One shaded Module". I noted that this problem seems to happen only with "Twin-half-Cut" module: If I select a "In length" module, both dialoguess give me the same results I think therefore there is a problem with the calculation of the electrical layout in this specific dialog. I will create an issue to investigate it further and fix this problem in a future version.
Luca Antognini Posted 20 hours ago Posted 20 hours ago Hello, In the simulation, the Arev factor and reverse characteristic is not influenced by temperature nor irradiance level. Is that what you're asking? Please consult also our Q&A on how to simulate those device in PVsyst in the current version:
