Changes required in PAN file if we change the Cell Efficiency or Cell Manufacturers ?
Is there any change required in the PAN file if we change the Solar Cell ?
If yes then what are the changes required?
What are the changes in the PAN file required if we are changing the Cell Dimensions but the same technology.
  • 2 weeks later...
By definition a .PAN represents a PV modules with its performance.
Even withing the same technology, there are a lot of variations of solar cell performance - from providers, from batch-to-batch, from improvement in the production line etc...
So if you change the solar cells, it becomes a completly different product and all the values entered in the .PAN file should be reviewed for consistency.
Now it all depends what is your simulation goal by doing this. I can only answer your question if you give me more details and context.
