Aidenn Posted November 12 Posted November 12 Hi PVSyst Community, Is there a turnaround so I can define this config in the powersharing option in PVSyst? For context, 1A.PCS.7 uses SG4400 as inverter and at 27m/s. It exceeds the 4MPPT capacity of the inverter and the PVSyst reads this configuration as 2 INV instead of 1. MPPT1 - 585W - 81str MPPT2 - 585W - 82str MPPT3 - 585W - 47str 590W - 36 str MPPT4 - 590W - 20 str 595W - 60 str Thanks for the help!
Michele Oliosi Posted November 13 Posted November 13 Unfortunately, it is not possible to put two different types of string on the same MPPT in PVsyst. You must either approximate the module rated power so that the MPPT are homogeneous, or you should redefine the inverter as having 6 MPPT, although this could somewhat affect the inverter losses.
