pongsakornnorcum Posted October 30, 2025 Posted October 30, 2025 I’ve uploaded the 3D file, but it still shows this. What could be the cause? Even after I moved the panels as far apart as possible, it still appears. - How to fix it?
Muhammed Sarikaya Posted October 30, 2025 Posted October 30, 2025 Dear, You can disable this check in Near Shadings by going to: Tools → Disable field interpenetration check See below: Regards,
Toni Posted November 10, 2025 Posted November 10, 2025 Hi, I have the problem that when I select the "Automatic altitude" and set a distance to ground of 0,8m, PVsyst does not apply it. The panels are still going underneath the topology. Does anymone have a solution or advice ? Kind regards, Toni
Stéphane Degré Posted November 10, 2025 Posted November 10, 2025 Dear Toni, don't hesitate to email us your project at support@pvsyst.com so that we can replicate the issue and try to help you.
