PVsystCLI Trial stopped working — license file missing error
I was testing PVsystCLI normally, and suddenly the following error started to appear:
The license file "C:\ProgramData\PVsystCLI\PVsystCLI.lic" is missing.
You can run "lic-activate" command to activate your license.
When I run the command PVsystCLI lic-info, I get the following information:
Status: TRIAL
Remaining days: 17
Remaining executions: 208
Host ID: HARDDISK=0000_0000_0000_0001_8CE3_8E05_00AE_DC3E., ETHERNET=0A0027000004||70A8D3D028D0||72A8D3D028CF||70A8D3D028CF||70A8D3D028D3||B44506AB2282, WIN_PRODUCT_ID=00342-43291-73682-AAOEM, BIOS=752V6R3
It clearly says that my Trial license is still valid, but the CLI doesn’t run any simulations — it just stops with the “license file missing” error.
I didn’t change anything in my system configuration, and this issue appeared suddenly.
What should I do to make PVsystCLI work again during the trial period?
Dear Renan,
Thank you for reaching out.
Even if you got the information message
the simulation should perform if you are still in TRIAL mode.
Could you please export and send us your PVsystCLI log files to support@pvsyst.com (you can generate PVsystCLI logs with the command "PVsystCLI export-logs")
Best regards.
