I don't see what you mean by "some modules are overlapping".
For filling your field, you can do that manually by the mouse.
But you can possibly use the option "Attribution automatique"  (you have many options for doing this), and than correct what seems not suited for you, by exchanging/dragging the string attributions with the mouse.
  • 1 month later...
Oh, I thought I would be notified when I got a response.
Basically, I have two PV module arrays. One array is on top of the other array, which is why they overlap. So, when I want to manually create an electrical string with my mouse, I can only modify the modules from the bottom array in the area where they overlap
@Michele Oliosi Thanks for your reply.
Ok, I will use the automatic attribution. Sometimes the automatic attribution doesn’t do what I want. So, I’ll patiently wait for the next update when it’s fixed.
