LauraH Posted May 27, 2025 Posted May 27, 2025 Hi, Are we still not able to export SIT files in v. 8? I'm trying to upload a new met file for an existing project but can't pick the appropriate site because it's not in the list. I don't want to create a new site at the risk of changing the model. Any suggestions? Thanks, Laura
dtarin Posted May 27, 2025 Posted May 27, 2025 Have you tried creating a copy of the SIT file in the Sites folder, to see if it shows up in the list?
LauraH Posted October 24, 2025 Author Posted October 24, 2025 On 5/27/2025 at 1:36 PM, dtarin said: Have you tried creating a copy of the SIT file in the Sites folder, to see if it shows up in the list? There is no corresponding SIT file in the Sites folder. That's the problem. I got the project file from another user and can't upload the met file because there IS no site file. This has always been the problem with project exports. I tried downloading the SIT file by using "Export table" after clicking to open the site on the project's main page. That gets me some of the info, but not a SIT file.
dtarin Posted October 25, 2025 Posted October 25, 2025 (edited) You can always create one from notepad just to get it loaded or extract the site information from the .prj file. Look for the following (and remove the text after the underscore). Some changes will need to be made; I think you just need to add the version below the "Comment=..." line. If you're creating from scratch, I think the main things you need are coordinates, altitude, timezone. The meteo data that is contained in the site file is not used in simulation. PVObject_SitePrj=pvSite .... .... End of PVObject pvSite Edited October 25, 2025 by dtarin
dtarin Posted October 25, 2025 Posted October 25, 2025 (edited) After writing that, perhaps the issue is that your prj file itself is missing the .SIT information, in which case manual creation might be the solution. Edited October 25, 2025 by dtarin
LauraH Posted October 30, 2025 Author Posted October 30, 2025 This all seems like a lot more work than having the project export include a SIT file. Why can't we just have that? Normally, when passing an export file to someone else, we copy the SIT file from the data directory and send that as well. It's not a good use of time and is easy to forget.
