No import of meteo data, after selected and confirmed location
After I selected the site location (by coordinates), PVsyst still asks for the altitude, even if it's already typed in. It does not import the meteo data and I can not continue. The problem is still present, if I choose other weather data and there's a internet connection (as I've chosen the location from the interactive map).
What can I do, to get the meteo files imported ?
Thanx, Toni
  • 1 month later...
On 3/4/2025 at 4:42 PM, Michele Oliosi said:
Hi, which version of PVsyst are you on ? This might be corrected by updating.
Thank you for your reply - I am using the version 7.4.7 (rev. 37278).
When starting PVsyst during booting it's searching fo updates, however when I click on help-> update program I receive a failure messaage (see image below):
 Do I need to upgrade to new versions to enable updates ?
Thanx for any help....
4 hours ago, Laurent C said:
Hello Toni,
The location of the downlaoded installer might have some permission restriction, preventing you to save it.
You can try by downloading directly from our website https://www.pvsyst.com/download/latest
Thank you for your prompt reply - I will first need to check with my system administrator.
Posted (edited)
I have the same issue. Using PVsyst 8.0.9 And I have been lead to believe I've got full admin privileges for this machine. (I can download and install this software.)
Edited by JMC
Clarifying PVsyst Version
