Error for two orientation when imprting PVcase PVC file
After importing PVC file, getting this error, "Orientation #2 "Tracking horizontal axis, Azim. 0.0°, Average": No attached subarray in the System part!". But in the orientation tab, every parameter is the same. See below snip. There are two orientations one has backtracking and another with average. I deleted orientation 1 from the 3D scene and all trackers from orientation 1 to orientation 2 with average and selected average from the pop-up received. What is the reason behind it even when all parameters are the same?
Dear Shivam,
I need to investigate your project, so could you please send it to us as a zip file at "support@pvsyst.com" by following this process:
File - Export projects - select the project
Regards,
Muhammed Sarikaya
