Alberto Cerrone Posted Wednesday at 03:00 PM Posted Wednesday at 03:00 PM Hello, i need a help, i have a layout i have made on autocad, converted to a DAE file and it work perfectly.. now i have learned that i can download from pvsyst ground levels, now, how i can adapt my plan layout to the ground level i have downloaded?
Alberto Cerrone Posted Wednesday at 04:13 PM Author Posted Wednesday at 04:13 PM i not know why in that case after i dragger the plant in position on the ground file my modules automatically adjusted based on the ground levels, i had just to lower the ground reticle otherwise pvsyst will give error of conpenetrating objects. now if i want to do that thing again it not work my plant remains flat. help me please
Jeremie Posted Thursday at 03:46 PM Posted Thursday at 03:46 PM Hello. Did you use the automatic altitude feature? Right-click on the PV fields you want to adjust at the level of the ground and select 'Automatic altitude'. Does it fit on your ground?
Alberto Cerrone Posted Thursday at 04:37 PM Author Posted Thursday at 04:37 PM yes but i still recieve the error of conpenetrating so i have to lower just a little bit the ground . is there a way to also reduce the size of the ground after i have finished to place the layout? and i have another question but of another kind.. if i have a 27 module string, but my pv layout is made of 9 modules arrays , how i can set the string in the shading scenes to make it considere 3 arrays as one string? the minimum x , y values i can set are 1 so i not know if it is possible to do to
