Nikoloz Posted December 10, 2024 Posted December 10, 2024 (edited) Hello I found some strange thing in 3d shading scene.... after i finished project with all simulations, I realised that in simuation report the camra viw angle on "Near shadings paameter" page was in "Perspectice view" and after I've changed it to "Top view" it asked me to recalculate shading factor table and smulation again.(I did not touched PV modules or tables, just changed the point of view. and it is every time I change the view point... is this ok or is this a BUG ???? it was not like this in previous versions and was very comfortable. 🙂 Edited December 10, 2024 by Nikoloz
Hizir Apaydin Posted December 12, 2024 Posted December 12, 2024 Dear Nikoloz, Thank you for bringing this issue to our attention. It was indeed introduced in PVsyst 8. We have noted the problem and will address it in a future update. Best regards,
Nikoloz Posted December 19, 2024 Author Posted December 19, 2024 (edited) Thanx One more question 🙂 in Project's name field it does not recognize dots . on File Name instead of dots it shows _ for example I have created project with name " Karaleti_66.46.01.672.001" but the file name is "Karaleti_66_46_01_672_001_Project.VC0-Report.pdf" . These dots are important 66.46.01.672.001 - 66_46_01_672_001 This is a code of a plot of land where client is going to build plant. Is it possible to use just dots ? Edited December 19, 2024 by Nikoloz
Hizir Apaydin Posted December 20, 2024 Posted December 20, 2024 Dear Nikoloz, When clicking on "Save" from the main project window, you are free to update the project file name and replace "_" by "." . Then, when generating the report and saving the PDF file, it will keep the dots. Best regards
Nikoloz Posted December 26, 2024 Author Posted December 26, 2024 one more question, when I try to change name and save project as different project the old one dissapears ( There is often situation when custome has 2 nearby ground fields and wants to make 2 PV Plants wth the same power and not to make 2 project there is no button with "Save as" ).. is it possible to ''Save as'' ? there is only "Save active project"
