Mike99 Posted November 14 Posted November 14 Hi everyone, I'm just trying to understand which irradiance value is actually representing the POA irradiance from the simulation result raw data below. Is it GlobInc column or I need to calculate it? date GlobInc GlobEff EArray E_Grid PR GlobHor DiffHor T_Amb WindVel BeamHor W/m² W/m² kW kW ratio W/m² W/m² °C m/s W/m² 01/01/90 00:00 0 0 0 -29.764 0 0 0 -4.6099 3.5 0 01/01/90 01:00 0 0 0 -29.764 0 0 0 -4.6903 2.9 0 01/01/90 02:00 0 0 0 -29.764 0 0 0 -5.2298 2.5999 0 01/01/90 03:00 0 0 0 -29.764 0 0 0 -5.5203 2.9 0 01/01/90 04:00 0 0 0 -29.764 0 0 0 -5.8099 2.7999 0 01/01/90 05:00 0 0 0 -29.764 0 0 0 -6.1004 3.1 0 01/01/90 06:00 0 0 0 -29.764 0 0 0 -6.3097 2.7 0 01/01/90 07:00 0 0 0 -29.764 0 0 0 -6.5197 3.5 0 01/01/90 08:00 12.703 8.0465 231.68 87.673 0.2641 14.806 14.797 -6.1696 3.1 0.0094 01/01/90 09:00 245.44 118.33 2798.4 2710.9 0.4226 112.3 63.302 -4.9298 4.5999 48.996 01/01/90 10:00 256.56 149.41 3831.8 3733 0.5567 165.99 127.2 -4.08 4.1 38.796 01/01/90 11:00 287.94 177.34 4592.7 4484.7 0.5959 196.1 156.2 -3.4696 3.9 39.908 01/01/90 12:00 245.12 152.5 4208.2 4105.1 0.6408 184.8 157.5 -3.1903 4.3999 27.303 01/01/90 13:00 267.76 162.32 4249.2 4145.6 0.5924 181.7 145.2 -3.0303 4.9 36.502 01/01/90 14:00 207.67 118.55 3201.4 3109.7 0.5729 137.39 113.2 -3.1099 4.1 24.195 01/01/90 15:00 108.34 53.481 1474.8 1371 0.4842 66.401 57.002 -3.5802 5.7 9.3984 Any help would be appreciated, Thanks,
Mike99 Posted November 14 Author Posted November 14 Thanks for the answer Dtrain, my system is actually having bifacial modules, how can I get the total irradiance from this raw data? Does POA actually equals to front POA+ rear POA, or there is an equation to get overall POA for bifacial systems?
Michele Oliosi Posted November 15 Posted November 15 Do you want to have the theoretical plane of array irradiance without shadings, horizon, etc, or the effective irradiance you would measure front side / back side ? The backside POA irradiance (without applying shadings or horizon) is GlobBak + BackShd (GlobBak has had shadings applied, so some irradiance needs to be reintroduced). GlobInc is the POA irradiance on the front side (without applying shadings, etc).
Mike99 Posted Monday at 05:27 PM Author Posted Monday at 05:27 PM I'm trying to do PV system capacity test, and in my real measurement data I do have front and back irradiance measurements, so I am trying to match what I have from actual measurements to PVsyst model, in this case I believe I need GlobBak which has had shading applied. Just another question on how I can extract the GlobBak data when I extract the weather data from PVsyst, it seems it is not in my export at the moment. I am not able to see it under Data display and verification->Tables->Variables. Thanks,
Michele Oliosi Posted Tuesday at 12:55 PM Posted Tuesday at 12:55 PM GlobBak is not technically weather data, since it depends on the system definition. You should instead run the simulation and create an output file: https://www.pvsyst.com/help/project-design/simulation/create-a-csv-file-of-hourly-daily-values.html So is BackShd. Note that if you have defined an horizon profile, you should rather use GlobHrz, instead of GlobInc, for the frontside POA. Indeed, the horizon also affects the solarimeter.
