Swonno Posted November 7, 2024 Posted November 7, 2024 Good afternoon from Korea. Can I have a question? The Orientation update button doesn't run. So I moved to the Orientataion management tool and changed til 5degree but It seems like it`s not working. The Mesh #14 is the flat modules wich is 0degree. What can I try next? Pls help thanks.
Swonno Posted November 7, 2024 Author Posted November 7, 2024 I adjusted tilt management degree and it works not thanks!!
Swonno Posted November 7, 2024 Author Posted November 7, 2024 (edited) Is there any tips to run the simulation? Because I succed to arrange various orientations but even small capacitiy orientation is needed to same inverter but this inverter is too oversized for this. I didn't expect this small capacity orientation.... Do you have any guide line at this situation??? Inverter size is planned for 125kW but I desized to 50kW but i can see error. Edited November 7, 2024 by Swonno
Muhammed Sarikaya Posted November 7, 2024 Posted November 7, 2024 Dear Swonno, You can modify the limit parameter to allow PVsyst to run the simulation. Got to "Settings-Edit advanced parameters" In the search box, type "inverter" and find the line "The Inverter power is strongly oversized." Adjust the ratio to, for example, 0.1 as follows: This will enable you to run your simulation. Don’t hesitate to reach out to us if you have any questions. Regards, Muhammed Sarikaya
