Module & Terrain Coordinate Mismatch
Hello PVSyst Team,
I'm using Sketchup to design terrain and modules at the same time.
But a thing is when i try to export from Sketchup to PVSyst with 3DS files,
I usually export in a two different files. One is only for modules and the other is only terrain file.
And When I import two seperately , It doesn't matech well.
Pls help how can i match those with.
One more question is, When I import from Sketchup,
Some array is wholed or transformed as a line. Pls guide me.
Thanks
Dear Swonno,
From SketchUp, it's important to assign a material to the surface of the PV module. You can also assign a material named 'ground' to it in SketchUp. Then, when you import into PVsyst, you must define what is a PV object by checking the box corresponding to the material name, and what is a terrain object by selecting the box with the associated name. I invite you to read our tutorial on this topic. Here's how you can find it:
Regards,
Muhammed Sarikaya
On 11/1/2024 at 4:15 PM, Muhammed Sarikaya said:
Dear Swonno,
Regards,
Muhammed Sarikaya
Thank you This is helpful.
