Abeer Posted September 25, 2024 Posted September 25, 2024 How can I adjust the altitude after importing site data as a custom file? The expected altitude is 757, but after import, it shows 774.
Agnes Bridel Posted September 26, 2024 Posted September 26, 2024 You should be able to change the altitude in the "Conversion of custom (sub-)hourly weather data files" window. After selecting your source file, you can click on "New" to select your site, and here you have the possibility to modify the altitude, which then will be taken into account in the simulation. Best,
Abeer Posted September 26, 2024 Author Posted September 26, 2024 On 9/26/2024 at 9:46 AM, Agnes Bridel said: You should be able to change the altitude in the "Conversion of custom (sub-)hourly weather data files" window. After selecting your source file, you can click on "New" to select your site, and here you have the possibility to modify the altitude, which then will be taken into account in the simulation. Best, Expand Thank you for your assistance. However, I wasn't able to locate any option in the site file to adjust the altitude. Could you kindly provide further explanation or share a screenshot to guide me? Best regards,
