Abeer Posted August 31, 2024 Posted August 31, 2024 How can I import an Excel file containing one year of hourly meteorological data into PVsyst?
Agnes Bridel Posted September 2, 2024 Posted September 2, 2024 The most straightforward is to prepare your excel file in the PVsyst standard format for hourly meteo data. You can then import the file directly through "Databases > Known format" and select the PVsyst standard format from the dropdown menu. For more information on the format, please refer to the help page: https://www.pvsyst.com/help/index.html?meteo_pvsyst_standard_format.htm Otherwise, you also have the possibility to import your data through "Databases > Custom file". You will have to define the conversion protocol (MEF file) so that PVsyst can convert it to a MET file for the simulation. A step by step explanation on the custom file import can be found on the help page https://www.pvsyst.com/help/index.html?meteo_convdialog.htm Best,
