André Mermoud Posted October 1, 2012 Posted October 1, 2012 For the versions 5.xxSince version 5.2, depends on your Windows OS:- Under Vista and Windows 7: c: \ ProgramData \ PVsyst \ Data \- Under XP and olders: c: \ Documents and Settings \ All Users \ Application Data \ PVsyst \ Data \Now you can also have yourself delocalized the data structure anywhere else (i.e. created directory "PVsyst_Data"). The directories actually in use are listed in the dialog "Files" / "Directories"It is possible that you don't see the c:\ProgramData\ directory: see "I don't see a folder "\ProgramData\" on my machine".It is also possible that you don't find your data in the c:\ProgramData\PVsyst\Data\ directory: please see "I don't find my files in the \Data\ structure".For the versions 6.xxThe data structure is normally in c:\Users\"yourSession"\PVsyst6_Data\If you have displaced them the actual path in mentioned in the main menu of the software: "Files" / "Workspace", User workspace ...You will find a complete description of the Database structure and localization in the Help: "Technical aspects > File organisation > User data > Projects and PV components".
