JoaoReis Posted July 17, 2024 Posted July 17, 2024 Hi everyone. I'm simulating the terrain in PVSyst. I divided the system into 5 sub-array orientations. In 'Main Parameters>System' I correctly correlated the number of modules for each Orientation with the number of modules in the 3D scene. However, even if the number of modules is correctly listed, the message is displayed as shown in the image below. I am unable to continue with the simulation. I already increased the area of the 3D scene and it didn't work.
JoaoReis Posted July 18, 2024 Author Posted July 18, 2024 Hello dtarin. Thanks for your response. I made the changes you suggested. However, it still has the same error. Do you know of any other configuration to be done?
Stéphane Posted July 19, 2024 Posted July 19, 2024 Hello JoaoReis. You can send us your project files at support@pvsyst.com so that we can have a closer look and try to help you. You can export the project from the main window > File > Export projects.
JoaoReis Posted July 19, 2024 Author Posted July 19, 2024 Hello Stéphane. Thanks. Yes, I can send you an email.
