Lima Posted July 17, 2024 Posted July 17, 2024 why is the near shadings for a tracker system with 13 degrees and a minimum above ground of 2.1m has 0.3% near shadings and that of 60 degrees and 0.5m above ground has almost around 3%? How does pvsyst calculate this?
Michele Oliosi Posted July 18, 2024 Posted July 18, 2024 The minimum height above ground is not very relevant to the near shadings. If your trackers go to 60° rotation angles: - it means they will follow the sun much lower than the 13° ones, inducing more mutual shadings if backtracking is not active - the diffuse component is also subject to more mutual shadings
Lima Posted July 18, 2024 Author Posted July 18, 2024 What is then difference between near shadings and electrical string shadings?
Michele Oliosi Posted July 18, 2024 Posted July 18, 2024 near shadings : irradiance loss electrical shadings : electrical mismatch loss caused by partial shadings
