Vera Posted July 11 Share Posted July 11 I calculated the monthly albedo for the site and imputed the data into the into the project settings. The report is showing the monthly albedo here: However the inputted albedo settings did not seem to apply to the simulation calculations, the average yearly albedo should be .21 but the report is showing a ground albedo of .3 in this section here: and .3 here as well here: No change to the calculations was made after inputting the monthly albedo. How can I get the proper albedo to apply? Thank you, Vera Link to comment Share on other sites More sharing options...
Muhammed Sarikaya Posted July 12 Share Posted July 12 Dear Vera, The albedo you have modified surrounds the entire PV plant. For a bifacial system, you have the option to define the ground albedo beneath the PV modules. I invite you to watch our tutorial on bifacial modules on YouTube, where you will find how to set this ground albedo factor. Here the link: Regards, Muhammed Sarikaya Link to comment Share on other sites More sharing options...
Vera Posted July 16 Author Share Posted July 16 Thank you! Link to comment Share on other sites More sharing options...
