JamesLenton Posted May 10, 2024 Posted May 10, 2024 Hi guys, I am attempting to define tables in the 3D scene which are 3 in portrait but in some cases are 'missing a module(s). The string length is 28 and the site was filled with these 3 table sizes for 1, 2, and 3 strings. This leads to the 1 and 2 string tables having non equal number of modules on each row. Is there an easy way to do this in PVsyst, without defining a small table and then adding 1 or 2 modules by themselves? Any suggestions are appreciated!
Muhammed Sarikaya Posted May 10, 2024 Posted May 10, 2024 Dear James, Could you please share a screenshot of your system? It's unclear why some modules are missing. Regards, Muhammed Sarikaya
JamesLenton Posted May 10, 2024 Author Posted May 10, 2024 Hi Muhammed, Sorry I can't share that. It is where smaller tables have been used to fill the more narrow parts of the available land - and the table sizes that were used for this are shown in the image I posted. I think it was so the table sizes were in 1, 2, and 3 strings. James.
Muhammed Sarikaya Posted May 10, 2024 Posted May 10, 2024 Dear James, Can you explain your procedure for creating this table so I can understand what went wrong? Regards, Muhammed Sarikaya
JamesLenton Posted May 10, 2024 Author Posted May 10, 2024 I think my use of the work 'missing' is confusing things. The actual design was made this way, and I am trying to replicate it. And I am wondering if were is an easy way of doing this. Thanks, James.
Muhammed Sarikaya Posted May 10, 2024 Posted May 10, 2024 Dear James, I understand what you want to do. You need to create a polygonal PV plane. Then, right-click to delete one or more modules when you position the mouse over a PV module. Regards, Muhammed Sarikaya
JamesLenton Posted May 10, 2024 Author Posted May 10, 2024 Hi Muhammed, Thank you so much for your help! I just didn't look hard enough to find that tool! Have a good weekend, James.
JamesLenton Posted May 13, 2024 Author Posted May 13, 2024 Hi Muhammed, I have added the polygonal fields to my 3D scene, however I am now getting an error with the bifacial system definition: "not all you table widths are identical - system not suited for bifacial 2D model computation". Can you not define bifacial modules for polygonal PV planes? Best, James.
Muhammed Sarikaya Posted May 13, 2024 Posted May 13, 2024 Dear James, Polygonal tables are not suitable for bifacial systems. I suggest using a full table, but be aware that your shading calculation might be slightly higher than the actual value. Regards,
JamesLenton Posted May 13, 2024 Author Posted May 13, 2024 Thanks for updating me. Is this something that will change as PVsyst version 8 is released? When can we expect more information on version 8? Best, James.
JamesLenton Posted March 3 Author Posted March 3 Hi Muhammed, hope you are well. I have tried modelling a site with polygonal tables as per a site design, now with PVsyst version 8. Has bifacial modelling for these tables been added in yet, or is it planned for a future update of version 8? Kind regards, James.
Muhammed Sarikaya Posted March 3 Posted March 3 Dear James, With bifacial modules, we can create projects with multiple orientations in the 3D scene. However, you must meet certain conditions: The PV tables must have the same width. The pitch between rows must be uniform. All PV tables must be identical. See the helps: https://www.pvsyst.com/help/project-design/bifacial-systems/2d-bifacial-model-conditions.html Regards,
