Douglas_L Posted March 13 Share Posted March 13 I got this error importing a 3D-scene from Helios. This is a new error and i don't understand the cause. How can this be fixed in able to simulate? Link to comment Share on other sites More sharing options...
Stéphane Posted March 13 Share Posted March 13 Dear Douglas, To get rid of the error message, you can go to the advanced parameters (menu “Settings > Edit advanced parameters” from PVsyst first window), search for “spread” and modify the following value: Please keep in mind that the default value is 4° so increasing it can lead to results that are not entirely accurate, but at least you will be able to run the simulation. Link to comment Share on other sites More sharing options...
kennyyan Posted Tuesday at 02:43 AM Share Posted Tuesday at 02:43 AM On 3/13/2024 at 7:10 PM, Stéphane said: Dear Douglas, To get rid of the error message, you can go to the advanced parameters (menu “Settings > Edit advanced parameters” from PVsyst first window), search for “spread” and modify the following value: Please keep in mind that the default value is 4° so increasing it can lead to results that are not entirely accurate, but at least you will be able to run the simulation. Hello, will this have impact on the result? I also have the problem when inputing the dae file, N-S tracker 3D model into the pvsyst, selecting N-S type, but still software show tilted axis in the model, same in the report. Any steps i was wrong? Link to comment Share on other sites More sharing options...
