JanGG Posted February 14, 2024 Posted February 14, 2024 Hello, At the moment I'm working on a PV-project mounted on a facade. However the software I'm working with (VirtoSolar) doesn't support facade systems. To get arround this problem I just made a flat roof 3D model in VirtoSolar, and I want to flip this .pvc model in PVSyst on it's side. Sadly this doesn't work for me, I'm only able to rotate the whole building arround the azimuth, and if I change the tilt angle it messes up the whole scene. Is there a way to change the origin or rotate the whole building on it's side?
Stéphane Posted February 15, 2024 Posted February 15, 2024 Hello. Unfortunately this is currently not possible in PVsyst. However your scene doesn't look too complex so you might be able to design it from sratch in PVsyst to achieve the desired result.
