Virgil Ciolponea Posted January 23, 2024 Posted January 23, 2024 Dear Team, I am trying to create a simulation in PVsyst with Tracking horizontal axis E-W and I have 2 problems: 1) I can not use bifacial modules when I use this configuration for my system. This is the error: .If I don t use bifacial modules I can run the simulation without any errors, but I need to do a bifacial simulation. 2) I don't know exactly which one of these variants is correct: If I use Tracking horizontal axis N-S and rotate the modules in the shading scene with an -90 azimuth practically resulting an Tracking horizontal axis E-W system. On the other hand, the production is slightly higher if I use directly Tracking horizontal axis E-W in the orientation and the shading scene. Which one of these simulation is correct? Kindly help me with this situation.
Michele Oliosi Posted January 23, 2024 Posted January 23, 2024 Dear Virgil Ciolponea, Are you sure you want to use E-W trackers? This type of tracker is more uncommon. NS-axis trackers (turn towards east in the morning and face west in the evening) are more common. Unfortunately, the bifacial calculation only handles NS-axis SAT at the moment. Even though PVsyst will formally allow turning the N-S axis tracker 90° around, it will not lead to good results, especially in backtracking mode (the backtracking of EW and NS axis trackers are different). If you need a bifacial gain value, I would suggest extrapolating the values using a fixed tilt variant to establish an approximation of the bifacial irradiance gains.
