I am currently working on an ongoing research project that involves analyzing decomposition and transposition models for Nordic climates.
Our results show that the default decomposition and transposition models in PVsyst yield higher uncertainties compared to alternative models for several of the analyzed locations. Specifically, the current options in PVsyst (Erbs and Perez) yield significantly higher uncertainties (rRMSD of 12,9% and rMBD of 4,3%) compared to other options with almost no bias in terms of rMBD and rRMSD below 10%.
Would it be possible to provide an option to perform the decomposition and transposition step separately and import a custom file containing not only GHI, but also DNI, DHI, and POA to PVsyst?
Alternatively, could you add more decomposition models and transposition models to choose from in PVsyst?
This sounds like a great research. Are you going to publish it? If so, we'd gladly go through it once it's out there.
In PVsyst you can always (and it is recommended to do so) import DHI or DNI in addition to GHI. This means that we do not need to rely on DirInt or Erbs for diffuse estimation.
Currently, it is also possible to import POA data as part of the custom file import (https://www.pvsyst.com/help/meteo_convdialog.htm). What this does is that it uses Hay for reverse transposition to get both GHI and DHI, and then uses these values for the simulation (as well as the Hay transposition). This means that the POA used in the simulation will be the imported one, however the decomposition in different irradiance components will be according to the Hay model.
We could add more decomposition / transposition models if necessary. We will establish this type of developments by first having a thorough look at the literature. I think your research would help us as a first step to assess the need to implement other transposition / decomposition models.
  • 1 year later...
There is already a huge amount of literature on this topic. As a start I would recommend [1].
As is usually the case with models, the parameters have been tuned for certain locations, so it makes sense to test them at many locations. In general one can say that Erbs usually overestimates the diffuse component under clear sky conditions, and this bias is severe (of the order of 25% using 10 minute data from a location in Western Europe). You won't see that statistic when looking at all the data (all sky), but if you specifically look at clear sky conditions, you will see that basically Erbs overestimates the atmospheric turbidity / aerosol optical depth, leading to a higher diffuse component. Put another way, the sky is clearer than what Erbs models it to be, there is less scattering  due to aerosols and more direct light. This error leads to underestimation of the direct component and underestimation of shading losses in PVsyst
It would definitely make sense to include DIRINT [2] in PVsyst, since that model uses more predictors, not just the clearness index. Specifically, DIRINT has a time component that takes into account variability, i.e. the change in clearness index. That helps then to distinguish between different weather conditions, and thus model them differently.
All of that being said, the best is to import diffuse irradiance, which is however not always possible if it is not measured on site.
[1] Gueymard, C. A., & Ruiz-Arias, J. A. (2016). Extensive worldwide validation and climate sensitivity analysis of direct irradiance predictions from 1-min global irradiance. Solar Energy, 128, 1–30. https://doi.org/https://doi.org/10.1016/j.solener.2015.10.010
[2] Perez, R. R., Ineichen, P., Maxwell, E. L., Seals, R. D., & Zelenka, A. (1992). Dynamic global-to-direct irradiance conversion model. ASHRAE Transactions, 354–369.
Posted (edited)
As quick extra note: according to the comparison paper by Gueymard and Ruiz-Arias [1] quoted above, the best performing model is in fact "Engerer 2" [3], since it is developed specifically for one minute data. However the next best model is the DIRINDEX [4] model, which is basically DIRINT with an additional predictor based on applying a clear sky model.
It would be great it PVsyst could consider using some of the more modern decomposition models, especially considering the use of high-frequency irradiance data.
[3] Engerer, N. A. (2015). Minute resolution estimates of the diffuse fraction of global irradiance for southeastern Australia. Solar Energy, 116, 215–237. https://doi.org/https://doi.org/10.1016/j.solener.2015.04.012
[4] Perez, R., Ineichen, P., Moore, K., Kmiecik, M., Chain, C., George, R., & Vignola, F. (2002). A new operational model for satellite-derived irradiances: description and validation. Solar Energy, 73(5), 307–317. https://doi.org/https://doi.org/10.1016/S0038-092X(02)00122-6
Edited by James Barry
Hi @James Barry
Thank you for the feedback. This comes in very timeline as we are currently assessing models for the decomposition of irradiance from GHI for minute data. We are aware that diffuse fraction models such as Erbs can be biased when applied on sub-hourly scales. Providing an alternative to Erbs is thus a necessity.
  • 2 weeks later...
  • 2 weeks later...
On 10/23/2025 at 9:32 AM, Michele Oliosi said:
Hi @James Barry
I would like to emphasize the point that in fact Erbs can lead to bias even on hourly time scales! I recently came across this again using diffuse data from DIRINDEX and comparing it to Erbs, i.e. standard PVsyst decomposition. In the winter months in this particular location the Erbs model led to a bias in the monthly sum of diffuse irradiance of between 10% and 18%, i.e. Erbs massively overestimated the diffuse fraction. So it is not only applicable to sub-hourly data.
