Hidayah Posted December 14, 2023 Posted December 14, 2023 When is version of PVsyst (V8.0) available? As of now, what is your advise if we need to stimulate plant with mix fixed and tracker?
Michele Oliosi Posted December 14, 2023 Posted December 14, 2023 In version 7, you should always do separate variants for fixed and tracker. We would like to publish version 8 during the first half of next year, but this is still uncertain, and we cannot yet give a more precise release window, unfortunately.
Hidayah Posted December 15, 2023 Author Posted December 15, 2023 Dear Michele, If we have want to design 20MWac inverter / 22.5MWdc fixed and 20MWac inverter / 22.5MWdc tracker with grid limitation curtailment at 30MWac. Our concern is how can we do simulation 30MWac without same variant. Can you advise? Thank you in advance for your reply.
Michele Oliosi Posted December 15, 2023 Posted December 15, 2023 This is not possible currently (not possible to have trackers and fixed in the same simulation in version 7). I would advise running both variants without grid limitation. You can define an output file (https://www.pvsyst.com/help/output_file.htm) for each of them. Then combine the output powers for each simulation step. You can then apply a grid limitation in another tool, e.g. in excel.
Hidayah Posted December 18, 2023 Author Posted December 18, 2023 Dear Michele, Thank you very much for your advise.
