How to export a 3d scenary with tracker axis phi inclination different from zero
Hello everyone,
I need your help with a scenary export problem:
In order to evaluate the producibility of a PV plant, I usually work with PVCase to discover how much peak Power I can install on the studied area. This software enables me to export in different formats and I can use it to work on PVSyst. My question is the following: can I export in a .dwg format the 3D scenary on which I am working on PVSyst? In addition to this,  I need to know also: can I export a plant scenary in which all the trackers are inclinated on an axis phi different from zero?
thank you in advance for the answer
