Abid Ali Posted August 9, 2023 Share Posted August 9, 2023 Hello, I am working on a research project to electrify a DC load with the direct supply from PV module(s) (without MPPT, battery storage or any power electronics). The objective is to investigate the performance of DC load under different voltages. Therefore, I want to adjust the PV module voltages through adjusting the tilt and orientation. I was wondering if there exists any tool/function in PVsyst where I can set the location, select a date, choose a PV module and check modules's hourly open circuit voltages for a particular user-set tilt/orientation setting. I hope my question is clear. However, if you need more clarification, please write me here. Thanks in advance Link to comment Share on other sites More sharing options...
Abid Ali Posted August 9, 2023 Author Share Posted August 9, 2023 6 minutes ago, Abid Ali said: Hello, I am working on a research project to electrify a DC load with the direct supply from PV module(s) (without MPPT, battery storage or any power electronics). The objective is to investigate the performance of DC load under different voltages. Therefore, I want to adjust the PV module voltages through adjusting the tilt and orientation. I was wondering if there exists any tool/function in PVsyst where I can set the location, select a date, choose a PV module and check modules's hourly open circuit voltages for a particular user-set tilt/orientation setting. I hope my question is clear. However, if you need more clarification, please write me here. Thanks in advance There is a graphic tool for the array's electrical behaviour (please refer to image). I am unable to see tilt/orientation option here Link to comment Share on other sites More sharing options...
dtarin Posted August 10, 2023 Share Posted August 10, 2023 Tilt and orientation will vary the current mostly as this changes amount of irradiance received. Temperature will affect the voltage more; irradiance, not so much. Link to comment Share on other sites More sharing options...
Abid Ali Posted August 10, 2023 Author Share Posted August 10, 2023 (edited) 9 hours ago, dtarin said: Tilt and orientation will vary the current mostly as this changes amount of irradiance received. Temperature will affect the voltage more; irradiance, not so much. Thanks. I understand and totally agree to this theoretically. However, I was wondering if PVsyst is equiped with some formulas for Voc that can tell the impact of facing of PV cell/module away from sun's position Edited August 10, 2023 by Abid Ali some typo errors Link to comment Share on other sites More sharing options...
dtarin Posted August 10, 2023 Share Posted August 10, 2023 (edited) NREL SAM might be a better option for this type of analysis, Voc is a variable you can output and viewin the results, so modifying tilt and checking the output is possible. Edited August 10, 2023 by dtarin Link to comment Share on other sites More sharing options...
