Andreza Maranhão Posted August 2, 2023 Posted August 2, 2023 When I create new variants in the project does the .PRJ change? I will put on example: I create three variants: VC1: Created a month ago VC2: Created a month ago VC3: Created today Why when I do the simulation again of VC1 anda VC2 today do the generations value change? The same VARIANTS but differents generation results. Why? The .PRJ files influences the results? How do I know which result is correct?
Nils Lang Posted August 2, 2023 Posted August 2, 2023 Dear Andreza Maranhão, You should get the same results. Please email us at support@pvsyst.com: 1. Your PVsyst LOG files (menu <File> <Export logs>) 2. Your project files (menu <File> <Export projects>) so we can analyze and try to reproduce the error you reported. Best regards.
