with the update to 7.4 the PVC import does not work properly. I have to correct the module layout for the tables. Each table has only 1 module for the x-axis and one for the y-axis. Module The distance between the modules is also not displayed. Import from pvdesign.
  • 3 weeks later...
  • 2 weeks later...
I am trying besides exporting the modules, to export the terrain also as a CSV file. But unfortunately when I insert the two in PVsyst, there is a mismatch. Do you know how I can fix the problem?
import reference images from the source you are importing from. CAD layouts, google, etc. use reference image to line up the objects. I would first move the image to match the PV and wind turbines, then move the terrain, just easier to select one object vs many
