MEURVILLE Posted June 26, 2023 Share Posted June 26, 2023 Good morning, I have several orientations on the same building for a dome row implementation. However in the "system" tab, I have no other choice than a single double orientation. How should I do it? Thanking you, Link to comment Share on other sites More sharing options...
Michele Oliosi Posted June 27, 2023 Share Posted June 27, 2023 For one pair of orientations, you should choose mixed 1 and 2. For the other pair, you need to play with the multi-MPPT power sharing options. This only works if the modules in orientation #3 are connected to a different MPPT than orientation #4. If so, you can make two subarrays, each with a different orientation (#3 and #4). You can then use the "orientation power sharing" (second tab in the "power sharing" window) to assign MPPT inputs to the same inverter. Link to comment Share on other sites More sharing options...
