Salvo Posted June 7, 2023 Posted June 7, 2023 Hi everyone, I tried to import a shading scene where there are both fixed and tracker panels and I have two different panels for each structure. I can't set up the simulation, also I get this error in the shading scene (which I don't have if I use only one type of fixed or tracker structure) “plane tilt =-1.9°, should be between 0° and 90° How can I do this simulation? Thank you in advance Regards Salvatore
Stéphane Metz Posted June 8, 2023 Posted June 8, 2023 Hi Salvo, Currently it is not possible to mix fixed panels and trackers in the same variant, this functionality will be available in the next major version of PVsyst (V8.0). Regards, S. Metz
