Could you please provide a practical example parameter file for for batch editing inverter makes. For example Bonfigliol_RPS_0571_MS.OND and SMA_Central500CP.OND Here is the automatically generated parameter file for SMA
Ident Nb module Nb strings Inverter Nb inverter
in series in parall *.OND File or MPPT
SIM_1 22 957 10 10
It seems to only work if Inverter *.OND file = 10 -
Thank you
Sebastian
There is indeed an error here: you should define the inverter's file name, but the corresponding column doesn't appear on the EXCEL table (try with the PV module: it works).
I will correct this for the next version 6.13.
After this correction, here is an example of how to define the EXCEL parameters document for running PVsyst in 3 simulations, with different inverters.
Example of the EXCEL definition with different inverters
