Wanderson Alves Posted April 12, 2023 Posted April 12, 2023 Estou simulando uma planta com potência nominal de 240MW. Porém, a potência injetada na rede deve ser limitada em 210MW. Ao fazer isso, utilizando o recurso de 'Grid power limitation', percebi que a energia produzida pelo sistema obteve um aumento significativo. Faz sentido limitar a potência injetada e obter aumento na produção de energia? Se sim, qual a possível explicação?
Lazare Fesnien Posted April 12, 2023 Posted April 12, 2023 Dear Wanderson Alves, Our discussion languages are French and English, please translate your email. Regards,
Wanderson Alves Posted April 12, 2023 Author Posted April 12, 2023 I am simulating a plant with a nominal capacity of 240MW. However, the power injected into the grid must be limited to 210MW. By doing this, using the 'Grid power limitation' resource, I noticed that the energy produced by the system obtained a significant increase. Does it make sense to limit the injected power and obtain an increase in energy production? If yes, what is the possible explanation?
