How do I get the Current inyected to the Grid?
I'm carrying out the simulation of a ground-mounted, grid-connected power plant, and I would like to know how to get a .csv or .xls file with the current during a year. The main results of the simulation display only the energy E_Grid [kWh]. I will need to use the current to calculate the loss (Joule effect) on the High Voltage cable.
Thanks in advance.
Hi, While the injected current is not an output in PVsyst, given E_Grid and the specific HV voltage, you can easily calculate the average current during each simulation hour. Just use the Advanced simulation > Output file tool to output E_Grid for each hour as a csv.
