dtarin Posted January 5, 2023 Posted January 5, 2023 The auto altitude function works for fixed tilt systems, but does not adjust the tilt for trackers. There is an automatic tilt function available when creating a zone of trackers, but if the tables are already created, there is no way to adapt their tilt to the terrain, only their elevation. It would be great to add this feature.
Michele Oliosi Posted January 6, 2023 Posted January 6, 2023 Hi @dtarin , thank you for the suggestion. I added a ticket on this topic.
Auxi Madero Posted November 13, 2023 Posted November 13, 2023 @Michele Oliosi Hello, I am having the same issue that @dtarin mentioned before, and I was wondering if it is something that has been already updated. I do not know if there is a way to proceed to calculate the tilt for a given group of trackers when I only want to modify the terrain.
Stéphane Degré Posted November 15, 2023 Posted November 15, 2023 Hello, This feature is still on our roadmap but it hasn't been implemented yet. Sorry for the inconvenience. Regards, Stéphane
Auxi Madero Posted November 15, 2023 Posted November 15, 2023 26 minutes ago, Stéphane Degré said: Hello, This feature is still on our roadmap but it hasn't been implemented yet. Sorry for the inconvenience. Regards, Stéphane Hello @Stéphane Degré, Many thanks for confirming. Do you know if there is an alternative that could be used in a similar way? Thanks, Auxi
Stéphane Degré Posted November 16, 2023 Posted November 16, 2023 Hello, No unfortunately currently there isn't any easy way to achieve this in PVsyst directly. The best approach would be to design your scene in an external software and then import it into PVsyst. Regards, Stéphane
