Thet Posted December 11, 2022 Posted December 11, 2022 Is that possible to connect the different orientations in series? We have 3 different orientations as follow: Orientiation#1 = -21 Degrees (50 Modules) Orientiation#2 = 78 Degrees (250 Modules) Orientiation#3 = 159 Degrees (100 Modules) Totals 400 Modules will be distributed to 100kW, 3 PCS and will use 20 series,20 string.So, I set in the system as below : Sub array #1 Orientiation#3 = 159 Degrees (100 Modules) 20 series and 5 strings Connected to 100kW 1 PCS Sub array #2 Mixed Orientation #1and #2= -21 Degrees (50 Modules)&78 Degrees (250 Modules) Total 300 Modules 20 series can not divided to 50 modules and 250 modules So I just set 20 series and 2 Strings for Orientation #1 20 series and 2 Strings for Orientation #2 Connected to 100kW PCS x 2 The problem is System didn’t match with Near Shading. Are there any other options to solve this problem? Thank you for your support always Best Regards,
Thet Posted December 11, 2022 Author Posted December 11, 2022 Edit Sub array #2 Mixed Orientation #1and #2= -21 Degrees (50 Modules)&78 Degrees (250 Modules) Total 300 Modules 20 series can not divided to 50 modules and 250 modules So I just set 20 series and 2 Strings for Orientation #1 20 series and 13 Strings for Orientation #2 Connected to 100kW PCS x 2
