I'm working on a stand alone system and have a question about the simulation result.
Actually the system is producing way to much energy compared to the consumption.
Excess Unused Energy is 1437 kWh per year
But still there is a Missing Energy Quantity of 97kWh per year.
I don't understand that to be honest?
Hope someone can help me out
Many thx
Ben
many thanks for your reply. Yes I have noticed that the missing energy can be seen in the diagram per month.
I'm playing a bit with the simulation of PVSyst with different Off Grid Designs. I must say that I don't understand
the behavior of the simulation completely. But probably that's because of my lack of knowledge (-:
I also don't understand all terms mentioned in the simulation report. I hope you can help me out. I already want to thank you for that.
First the load profile for the stand alone system:
The first system I designed has the following components:
3,300 Wp  PV Modules Longi 6 x 550 Watt Mono
Lithium batteries 3 x 48volt 100Ah
Outback Flex Max 60
The main results for this system are:image.thumb.jpeg.180176d05a92cfd6bf86ce73bbb9b0cd.jpeg
Actually there is a lot of excess (unused) energy.
The performance ratio is bad 55%
Missing energy is only 1.6% of the time, that’s good
How can we make this system better?
By better I mean:
Better Performance Ratio
Less unused energy.
Since there is a lot of unused energy I would expect that we can make the system smaller:
The second system I designed has the following components:
2,200 Wp  PV Modules Longi 4 x 550 Watt Mono
Morningstar Tristar 45 36 / 48
I have the following questions about these main result:
How can the specific production be 720 kWh/kWp/year compared with 1661 kWh/kWp/year of the first design. I would expect it to be close to each other.
The available energy is absolutely not enough to support the daily consumption of the household. 10.5 kWh.
365 x 10,5 kWh = 3833 kWh
Available energy = 1583 kWh
How can the simulation mention unused energy 1346 kWh, that is not possible in my view. There is a lack of energy of 3833 - 1583
How can the simulation mentioned missing energy 0 kWh / year
How is this possible?
Actually this looks like the most optimal system.
Performance ratio is good, no missing energy. So this looks like the best solution. But I really have my doubts about it. But I hope you can explain it to me.
Can you give some explanation about the terms
SOW ?
And why does the simulation of design 2 gives a battery life of 5 years while design 1 doesn’t?
Many many thanks
Kind regards
Ben
