How to use Ground object feature in Near shading?
I am trying to use Ground object feature for a complex solar project which will  build over the mountain.
My question are
Q1: How to use Ground object feature?
Q2:What kind of survey data do i need to use ground object feature?
Q3:Are there any training video of using Ground object feature?
That`s all.
Thank you for your always support.
Thet
Hi Thet,
There are 2 ways for create/modify grounds in PVsyst:
  1. Using the ground editor tool: https://www.pvsyst.com/help/index.html?ground_objects.htm
  2. Importing a CSV file with XYZ coordinates describing the ground: https://www.pvsyst.com/help/index.html?csv_ground_data.htm
After importing or creating your ground, you can use the zone tool to stake out your PV tables following the ground: https://www.pvsyst.com/help/index.html?zones_of_tables.htm
You will find a number of tutorial videos on our YouTube channel (https://www.youtube.com/c/PVsystTutos), but unfortunately there are no videos for these features yet.
