amp Posted September 23, 2022 Posted September 23, 2022 Hi, I am wondering why some bins associated with higher power injected into grid kW values have a drastically lower Energy injected into grid Mwh associated with them, then power bins with lower values? I understand that each bin has a width of 200kW, and is the sum of all the energy that was produce when the system was operating at the power range for one hour during the entire year. So ex: 1,800kW - 2,000kW -> 44Mwh but 1,600kW - 1,800kW -> 78MWh. Is there any reason why the drastic change? Is it bc of how the inverter operates? Also why on the Y axis it is stated MWh/ class of 50 kW? Thanks!
dtarin Posted September 23, 2022 Posted September 23, 2022 There are more hours in the year at one of the power output level compared to another. Filter your 8760 to verify.
dtarin Posted September 23, 2022 Posted September 23, 2022 50kW is your bin class size, not 200. Count the number of "steps", it is 20 steps to 1000, bin size of 50. The Y axis is MWh per each bin class of 50kW.
André Mermoud Posted September 26, 2022 Posted September 26, 2022 The classes are indeed of 50 kW (this is mentioned on the axis ... since the version 7.2.18! ). Now I don't have any explanation to this variability, this is a statistical variability.
sdguzman Posted March 26, 2023 Posted March 26, 2023 Eso significa que el sistema funciona más horas a 1800kW que a 2000kW. Energía= kW x hours Por las condiciones de la zona, y configuración del sistema, hay más probabilidad a trabajar más tiempo con potencia de salida a 1800kW. Si a las 2 potencias trabajan la mismas horas, obviamente que a mayor potencia genera más energía. Saludos!
