Bifacial simulation of system with azimuth and different orientations
I have a project that the bifacial solar panels are installed on the carport with slight inclination of 5 degrees and two orientations. however, PVsyst seems not able to run bifacial module simulation with azimuth even in one orientation. is there support for this kind of situation?
  • 10 months later...
For an eastwest module orientation plan, I would like to consider the bifacial modules as well. But unfortunately you can only do it for south alignment and tracker. Do you have a solution how I can consider this in PVsyst. Thank's
at present you can simulate bifacial PV installations that have
  • a single fixed or SAT orientation
  • at least two rows of tables / trackers
if you have a single row of tables, you should "duplicate" the scene, basically copy paste all relevant objects and place the copy at a large distance in the 3D scene. This will emulate the situation of a single row, because the original scene and the copy won't affect each other.
Note: this is the current workaround. We will try to offer a solution for single row scenes in the future.
