In the context of a 3D scene generated by DWG in .DAE, when fences, trees and buildings are taken into account, how can we make sure that the tolerance on the orientation allows us to have more than one average orientation for the whole scene?
Thank you in advance.
Thank you in advance,
Arnaud.P
Bouygues énergies et services - Montpellier
Hi Arnaud,
In the orientation management tool (3D scene : Tools > Orientation management) you can change the tolerance. If you reduce it you should have more average orientations.
Not sure if that answers your question though?
That's not quite the answer I was expecting, but in any case, thanks for taking the time to answer the question. Finally, I figured out what I wasn't doing right in the 3D scene. When Pvsyst asks to select the "PV" objects, you should only activate "frame" and not everything else. So I don't have any problem anymore. Thanks again for your help.
