yajmarc Posted June 1 Share Posted June 1 Hi! In this opportunity, I would like to know how to set the DC/AC ratio? I have 3 different ratios that I would like to test in my Pvsyst simulation. Link to comment Share on other sites More sharing options...
dtarin Posted June 1 Share Posted June 1 Increase or decrease the number of strings in your array under the system menu. Link to comment Share on other sites More sharing options...
Bruno Wittmer Posted June 2 Share Posted June 2 If you have many DC/AC ratios you would like to simulate, you can also use the 'batch mode', where you can change the number of strings and inverters to get different ratios. The batch mode allows you to run many simulations in one go, and it is described in the help pages in 'Project design > Simulation > Batch mode - Parametric studies'. Link to comment Share on other sites More sharing options...
yajmarc Posted June 9 Author Share Posted June 9 On 6/1/2022 at 3:26 PM, dtarin said: Increase or decrease the number of strings in your array under the system menu. Thank you very much Link to comment Share on other sites More sharing options...
