Abid Ali Posted April 21, 2022 Posted April 21, 2022 Hello I am using a licensed version of PVsyst, updated to version 7.2.14 (r25623). I am unable to find Carbon Balance Tool in PVsyst. Could you please suggest me where should I get this option? Best regards
Abid Ali Posted April 21, 2022 Author Posted April 21, 2022 29 minutes ago, Abid Ali said: Hello I am using a licensed version of PVsyst, updated to version 7.2.14 (r25623). I am unable to find Carbon Balance Tool in PVsyst. Could you please suggest me where should I get this option? Best regards I am working for Standalone PV systems
Lazare Fesnien Posted April 22, 2022 Posted April 22, 2022 Hi, The "Balance Carbon" tool has been disabled for StandAlone Systems. This tool is being maintained and improved for OFF Grid Systems
Abid Ali Posted April 22, 2022 Author Posted April 22, 2022 Thanks Lazare. I also noticed Aging option is disabled in Advance Simulation. I intend to calculate the yields for 20 years. Can you please suggest on this?
Lazare Fesnien Posted April 25, 2022 Posted April 25, 2022 Hi, Are you on grid connected system ? This isn't normal, did you run the simulation correctly ?
Abid Ali Posted April 25, 2022 Author Posted April 25, 2022 5 hours ago, Lazare Fesnien said: Hi, Are you on grid connected system ? This isn't normal, did you run the simulation correctly ? Hi, No, as I mentioned above, I am working for Stand-alone PV systems.
Lazare Fesnien Posted April 26, 2022 Posted April 26, 2022 Hi, This aging option for stand alone systems is currently disabled. The calculation of the battery degradation needs to be refined. We have re-enabled this feature with the new calculation for an upcoming major release.
Abid Ali Posted April 27, 2022 Author Posted April 27, 2022 Thanks for the reply. We hope to get the Aging AND Carbon Balance Tool for the stand alone systems in the upcoming release.
Neville Posted June 27, 2022 Posted June 27, 2022 Hi, On running simulation for a Ground mount project in Tanzania, the Carbon tool results are not appearing in the report. This is for a grid connect system with 7.2.16
