Debbie Posted March 10, 2022 Posted March 10, 2022 Hello, is there any way to revert back to a recent sub-version? For example from V7.2.12 to V7.2.11? I don't see the ability to download these sub-versions from the PVsyst website. Thanks in advance for the help.
Nils Lang Posted March 11, 2022 Posted March 11, 2022 You cannot have two patches of PVsyst 7.2 installed at the same time (note that you can have several versions of PVsyst installed in parallel on your computer like 7.2, 7.1, 7.0 and V6). But you can come back to a specific patch version by following this procedure: Uninstall your v7.2.x first (by running 7.2.x installer or from Windows) Install, for example, v7.2.11 using this link: https://www.pvsyst.com/download/bin/PVsyst-7.2.11.24303-setup.exe Once you have finalized your tests with version 7.2.11, you just have to accept the update suggested when PVsyst is started to switch back to last patch of 7.2.
Debbie Posted March 11, 2022 Author Posted March 11, 2022 Thank you, Nils! Is there a general place to access these earlier .exe files, or do we need to request them here on the forum?
Nils Lang Posted March 14, 2022 Posted March 14, 2022 There is no general place. If you need to come back to another specific version then you should send a request to support@pvsyst.com
Nils Lang Posted November 9, 2022 Posted November 9, 2022 All PVsyst V7 versions are now available for download using the following link: https://www.pvsyst.com/previous-versions/
