estewan Posted July 24, 2013 Posted July 24, 2013 Hi,I found the following error:http://sia1.subirimagenes.net/img/2013/07/24/13072406093425779.pngIt occurs when starting the simulation. The project already worked, I just updated to version 6.10 and tried to re-run the simulation but the project stopped working. http://sia1.subirimagenes.net/img/2013/07/24/130724061530950717.pngIt does not affect any other projects.Thanks,Esteban
estewan Posted July 24, 2013 Author Posted July 24, 2013 Ups... it just happened in another 2 projects.I don't know why some old projects work with the new version and others doesn't...
estewan Posted July 24, 2013 Author Posted July 24, 2013 Apparently it is related to the system orientation. PV projects with tracking systems doesn't work.
André Mermoud Posted July 24, 2013 Posted July 24, 2013 I have indeed done very deep modifications for the version 6.10 (completely rewritten the shading loss factors on diffuse for tracking, see the FAQ How is calculated the shading loss factor on diffuse with tracking systems ? ). And I have forgotten to treat the case when you define a tracking system, without defining the 3D shading scene. If you create your 3D system and ask for shadings, you will be able to run the simulation.I will of course protect the simulation against this case for the next version.NB: with the previous versions (before 5.10), when using the backtracking strategy the shading factor was null (by definition of the backtracking, for beam component), so that it didn't make much sense to construct the 3D scene. But now you have shading losses on the diffuse component, therefore you cannot avoid to construct the 3D scene anymore.
robadams Posted July 29, 2013 Posted July 29, 2013 When do you anticipate the next version. This has made it difficult for me to use version 6 with our current list of potential projects. Constructing the 3D scene is time consuming and for these sites, provides little value.
wyeager Posted July 31, 2013 Posted July 31, 2013 I also look forward to a future version which allows us to model tracking systems without having to define a 3D scene. Thank you!William
sjjoslin Posted August 1, 2013 Posted August 1, 2013 I'm having the same problem - none of my projects with tracking systems work! Please provide an update as soon as possible, without having to create a 3D shading scene. As robadams mentioned, creating a 3D scene is time consuming, and in many cases unnecessary.
André Mermoud Posted August 2, 2013 Posted August 2, 2013 The new version 6.11 should be released within about 2-3 weeks. However with this new development, simulation the backtracking without 3D scene is no more advised, since we found that the shadings on the diffuse are not negligible.
estewan Posted September 13, 2013 Author Posted September 13, 2013 Dear Andre,This is happening again (Error #9) but the other way around. It only works if I do not define the 3D shading scene. If I want to run the simulation using the shading scene, it does not work, and same error (as shown on my first message) appears.Thank you,EstebanP.S. I am using V6.11
André Mermoud Posted September 19, 2013 Posted September 19, 2013 Yes, sorry, I have found another error in this part.Corrected for the next version 6.12, to be released hopefully on 23/09/13.
