psmith Posted September 21, 2021 Posted September 21, 2021 I am a newbie on this . I was trying to understand few things on detailed computation of mismatch (Loss section that uses RMS of Voc and Isc). As I am seeing the help section , the IV curves are based on single diode model that has following parameters :I = Current supplied by the module [A].- Unknown V = Voltage at the terminals of the module [V].- Unknown IphRef = Photocurrent [A]IoRef = diode inverse saturation current [A]Rs = Series resistance [ohm].Rsh = Shunt resistance [ohm].Gamma= Diode quality factor, theoretically between 1 and 2, often lessq = Charge of the electron = 1.602·E-19 Coulombk = Bolzmann's constant = 1.381 E-23 J/K.Ncs = Number of cells in series.Tc = Effective temperature of the cells [Kelvin]As I understand we get IV curves from this equation .Now looking at the detailed computation, It uses RMS values of Voc and Isc and obtains statistical sample of Voc and Isc . It then uses them in generating IV curves after aligning Voc and Isc (summing etc) . But, As I see the single diode equation has these two parameters as unknown that is calculated from the photocurrent IphRef. I am not able to relate this part . How we are generating the new IV curves from the statistical sample . Are we using this same single diode equation to generate IV curves here or some more info is there? Or I am interpreting things incorrectly ??
André Mermoud Posted February 8, 2022 Posted February 8, 2022 The Mismatch between PV modules in an array is a rather rough calculation, based on a statistical distributions of the parameters. The phenomenon is mainly related to the mix of different I/V curves, by calculating the addition of currents (in series) and then voltages (strings in parallel). This is not really sensitive on the exact I/V curve of each PV module, so that we may avoid recalculating the I/V curve from the one-diode model for each module. The shape of each I/V curve will be very similar for all the concerned modules. Therefore this tool uses the basic I/V curve of the reference module, and performs a "scaling" if the voltage and the current according to the individual Voc and Isc of each module.
