Hi,
While defining the detailed losses I closed the window to check on something thinking that I will return later. Now I get a message "With a HV transfo you have to define the grid voltage." and I can't go back to Detailed losses. Where can I define the grid voltage from the available options?
iulian
i think it's here iulian.trisca. But you have to acess to the detail losses. I see your project get some error with the system configuration. So let check the system tab first.
https://i.imgur.com/Sw3LAh5.png
PVsyst Grid Voltage HV
  • 4 months later...
