AC Induction Motor Through PV
sairam
Dear sir,
i need to calculate solar pv sizing for motive load other than pumps.
how to calculate sizing of pv plant considering the motor kw rating only.
for example if i need to run 10 kw motor through solar pv only , how to size the solar capacity,
i.e. how to compensate motor starting current in PV Design.
i have not found any solution for this in any design literature.
Regards,
sairam
You cannot build a system without a battery, as the sun's production is never guaranteed.
Therefore the problem will be reduced to define a stand-alone system.
Your problem will be to find an inverter able to drive you motor, including the starting current. This is probably standard in the industry.
